Автор Тема: Продаются профессиональные студийные мониторы  (Прочитано 2610 раз)
alekrolik
Продаются профессиональные студийные мониторы Hafler M5 Main 2-way Reference (2 шт) и усилитель в комплекте Hafler TA1600.
Обращаться в личку:
M5 Specifications
Frequency Response 70Hz - 21kHz +/- 3dB
Power Handling 20 - 200 Watts
Nominal Impedance 6 Ohms
Total Harmonic Distortion (THD),
90dB @ 1 meter, on axis <3% 70-150Hz
<1% above 150Hz
High Frequency Driver 1" (25mm) silk dome/waveguide
Low Frequency Driver 5.25" (133mm) polypropylene/rolled nitrile rubber surround
Cabinet 5.3 liter, 4th order Butterworth vented, 5/8" MDF
Inputs 5-Way gold plated binding posts
Dimensions 12.25"H x 6.75"W x 7"D
Net Weight 12 lbs. (5.45kg.) net
Crossover
Filter Type 4th order Linkwitz-Riley
Tweeter Overload Protection 3.2kHz Zobel network
_______________________________________________________
TA1600 Specifications
Power Rating 60 Watts/channel @ 8 Ohms
75 Watts/channel @ 4 Ohms
Power Rating @ 1kHz, 0.1% THD
Total Harmonic Distortion (THD) n/a
Signal-to-Noise >102dB below rated output “A” Weighted
Full Power Bandwidth 1.0Hz to 300kHz (+0/–3dB)
Slew Rate 100V/µs
CMRR (Common Mode Rejection Ratio) >65dB at 1kHz
Input Impedance 47k Ohms per phase balanced/47k Ohms unbalanced
Gain +29dB maximum
Input Sensitivity Range 0.390V (@ 8 Ohms) per phase balanced
0.310V (@ 4 Ohms) per phase balanced
Damping Factor 350 (to 1kHz)
150 (to 10kHz)
18 (to 100kHz)
Power Consumption 60VA @ 120VAC (quiescent)
Indicators Power
Dimensions 19"W x 8.5"D* x 3.5"H (2-rack spaces)
(48cm x 25cm x 8.9cm)
Net Weight 22 lbs. (9.98kg)
